Server PlansAuthor: jawapro
Date: Tue 21/08/2007 09:22 PM
Ok, well strange as it may seem, there are still a few people out there that I haven’t told what exactly I’m planning to do with this server. So for their benefit, here is a short list of my plans regarding building myself a server.
Well, when I was at the last Axon LAN, I played some games and did some leeching (File Sharing) as per normal. But I got annoyed that I couldn’t do both at once. If you’re leeching (or more to the point, being leeched from), your system is normally getting hammered and can’t handle anything else.
So the solution is to have two systems. One to play games on, and the other to be your file server. The guy sitting two seats up from me at the LAN had the biggest file server there, with about 1.5 Terabytes or something huge.
So I decided to rebuild myself a server. I used to have one (called Mara) but it died of a sudden motherboard failure about 6 months ago.
So I want to build myself a new Mara. Well, I could easily find another PC, call it Mara – and be done with it.
But, being a geek, I decided to do more than that.
So I wanted a server that would look like a server. And this case fits that description. Only a geek would think that carting around such a huge computer would be cool, but that’s me.
Anyway – I could throw a motherboard, cpu, etc, and a heap of harddrives in here and call it finished. But I’m a little more adventurous than that this time. I’ve never done much in the way of case mods before – but this time I’ve decided to aim high.
Now there’s a problem with having a server at a LAN. You either need to lug around an extra screen and keyboard and things, or you need to swap between you game pc and server whenever you want to see what the servers doing. Not good.
You can also use Remote Desktop or something similar – but that’s not the best solution. Mainly because the network link will be being hammered, so the remote desktop probably won’t work terribly well. And besides, you want to be able to glance at the server while you’re still playing games – not going back to Windows and loading up a remote desktop session.
So my dream is to make this server self-contained. It’ll contain it’s own screen, keyboard, etc. All it will need is a power cable, and a network connection.
Now, the easiest and cheapest way to do that, is to use a laptop. So that’s my plan. Find a slightly decent laptop cheap, and mount it INTO the case. With a hatch at the top so you can access it.
Now, it will still have to access the server using Remote Desktop, but it’ll use a separate network card, so it gets full speed from that card.
So that means there’s a lot of cutting, and mounting work to be done to get the laptop in there and working.
And just to make things trickier, I’m also considering adding a UPS (battery) so it’ll survive those annoying power outages when someone accidentally unplugs the power for half the room.
And I’m also considering adding a small Gigabyte switch, so it can support a small LAN all on it’s own.
Those two depend largely on space, heat, and cost. But that’s my dream.
Plus I plan to paint it and add some nice touches to the exterior to make it look cooler (which it does pretty well on its own anyway).
And what’s with the dinosaurs on the top of the case in the photo? Well, they are the official mascots of this server project. They just arrived from ebay, which might explain why they look a little jet-lagged.
So my first step is to find myself a laptop, so I can work out how to mount it and how much space I’ll have left for everything else.
Might have to wait a few weeks until my ban account recovers from the big Camera spend-up though…..
Comments: 22
